[GRASS-user] gdal 1.4.1 problem??
Maciej Sieczka
tutey at o2.pl
Sat Jun 2 02:26:00 EDT 2007
Jarek Jasiewicz wrote:
>>> unfortunatly I cant complile gdal with grass. After configure, I have
>>> grass 5.7+,
>>> during make no warnings about grass has been presented
>>> Path are tha same as in 1.4.0
>> Why don't you use gdal-grass plugin?
> well, because it was a whim (kaprys) generally I didn't need gdal ,1.4.1
> or rather, I don't know if I shall need it. I turn back to 1.4.0 and
> problem dissapears
> I found some informations in different palces about problems with
> grass6.3 and gdal plugin on gdal.1.4.1.
There was a problem that one could not build gdal-grass 1.3.2 with
GRASS 6.3 CVS, due to changes in GRASS. However, this problem is
supposedly fixed with the release of gdal-grass 1.4.1 [1].
> The problem is known.
Are you reffering to the same problem as I?
[1]http://download.osgeo.org/gdal/gdal-grass-1.4.1.tar.gz
