[GRASS-user] gdal 1.4.1 problem??
Jarek Jasiewicz
jarekj at amu.edu.pl
Sat Jun 2 03:30:40 EDT 2007
Maciej Sieczka wrote:
> Jarek Jasiewicz wrote:
>>>> unfortunatly I cant complile gdal with grass. After configure, I have
>>>> grass 5.7+,
>>>> during make no warnings about grass has been presented
>>>> Path are tha same as in 1.4.0
>>> Why don't you use gdal-grass plugin?
>> well, because it was a whim (kaprys) generally I didn't need gdal ,1.4.1
>> or rather, I don't know if I shall need it. I turn back to 1.4.0 and
>> problem dissapears
>> I found some informations in different palces about problems with
>> grass6.3 and gdal plugin on gdal.1.4.1.
> There was a problem that one could not build gdal-grass 1.3.2 with
> GRASS 6.3 CVS, due to changes in GRASS. However, this problem is
> supposedly fixed with the release of gdal-grass 1.4.1 [1].
>> The problem is known.
> Are you reffering to the same problem as I?
> [1]http://download.osgeo.org/gdal/gdal-grass-1.4.1.tar.gz
Seems to be the same, but concern grass 6.2.1 (I use to use stable
version of grass to compile gdal and qgis)
pozdr.
Jarek
