[GRASS-user] problem with display monitors on mac
William Kyngesburye
woklist at kyngchaos.com
Sun Jun 3 14:07:07 EDT 2007
Is X11 running? I'm not sure about Larenzo's binaries, but X11 might
not start automatically.
If gis.m works, then you may be using the Aqua interface, which
doesn't need X11, but all the d.* commands need it still.
I'm not sure of the operational status of d.m, though. gis.m should
fully replace d.m functionality. It may be that d.m doesn't work in
Aqua mode.
I find that TclTk Aqua has usability problems - not all controls have
been Aquafied (like the sliders), and are larger than on other
platforms so layout gets slightly messed up, and NVIZ has occassional
problems. So I always recommend sticking to X11 for GRASS.
On Jun 3, 2007, at 12:40 PM, Maciej Tomaszczyk wrote:
> Hello
> I have problem with display monitors(d.m manager), when i want to
> display anything i get message;
> child process exited abnormally
> while executing
> "exec -- d.mon start=x0 >@ stdout 2>@ stderr"
> ("eval" body line 1)
> invoked from within
> "eval exec -- $cmd $args >@ stdout 2>@ stderr"
> (procedure "run" line 2)
> invoked from within
> "run "d.mon start=x0""
> (procedure "Dm::monitor" line 10)
> invoked from within
> "Dm::monitor"
> (procedure "Dm::display" line 6)
> invoked from within
> "Dm::display"
> ("uplevel" body line 1)
> invoked from within
> "uplevel \#0 $cmd"
> (procedure "Button::_release" line 18)
> invoked from within
> "Button::_release .mainframe.topf.tb0.bbox1.b0"
> (command bound to event)
> I tried d.mon command and got message:
> GRASS 6.2.1 (klodawa_nowa):~ > d.mon start=x0
> ERROR: no such monitor 'x0'
> No such monitor as 'x0'
> Problem selecting x0. Will try once more
> gis.m manager works properly
> I installed grass using binaries provided by Lorenzo Moretti
> My OS is Tiger
> Is it posible to fix it?
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"Those people who most want to rule people are, ipso-facto, those
least suited to do it."
- A rule of the universe, from the HitchHiker's Guide to the Galaxy
