PD: [GRASS-user] problem with display monitors on mac
Maciej Tomaszczyk
mtom at pgi.gov.pl
Sun Jun 3 14:43:19 EDT 2007
I tried to run grass with X11 and got the same error. There is a problem with nviz also.
I installed Lorenzo binaries becouse i want run qgis in grass. Before, i used binaries provided by you
but qgis did not work in grass. Now i have full functionality of qgis but dont have d.m and nviz.
Is it possible to install both version of grass(your and Lorenzo). After i installed Lorenzos binaries
yours stoped work.
regards
maciej
Maciej Tomaszczyk
Polish Geological Institute
Geological Mapping Department
-----Wiadomość oryginalna-----
Od: William Kyngesburye [mailto:woklist at kyngchaos.com]
Wysłano: N 2007-06-03 20:07
Do: Maciej Tomaszczyk
DW: grassuser at grass.itc.it
Temat: Re: [GRASS-user] problem with display monitors on mac
Is X11 running? I'm not sure about Larenzo's binaries, but X11 might
not start automatically.
If gis.m works, then you may be using the Aqua interface, which
doesn't need X11, but all the d.* commands need it still.
I'm not sure of the operational status of d.m, though. gis.m should
fully replace d.m functionality. It may be that d.m doesn't work in
Aqua mode.
I find that TclTk Aqua has usability problems - not all controls have
been Aquafied (like the sliders), and are larger than on other
platforms so layout gets slightly messed up, and NVIZ has occassional
problems. So I always recommend sticking to X11 for GRASS.
On Jun 3, 2007, at 12:40 PM, Maciej Tomaszczyk wrote:
> Hello
> I have problem with display monitors(d.m manager), when i want to
> display anything i get message;
> child process exited abnormally
> while executing
> "exec -- d.mon start=x0 >@ stdout 2>@ stderr"
> ("eval" body line 1)
> invoked from within
> "eval exec -- $cmd $args >@ stdout 2>@ stderr"
> (procedure "run" line 2)
> invoked from within
> "run "d.mon start=x0""
> (procedure "Dm::monitor" line 10)
> invoked from within
> "Dm::monitor"
> (procedure "Dm::display" line 6)
> invoked from within
> "Dm::display"
> ("uplevel" body line 1)
> invoked from within
> "uplevel \#0 $cmd"
> (procedure "Button::_release" line 18)
> invoked from within
> "Button::_release .mainframe.topf.tb0.bbox1.b0"
> (command bound to event)
> I tried d.mon command and got message:
> GRASS 6.2.1 (klodawa_nowa):~ > d.mon start=x0
> ERROR: no such monitor 'x0'
> No such monitor as 'x0'
> Problem selecting x0. Will try once more
> gis.m manager works properly
> I installed grass using binaries provided by Lorenzo Moretti
> My OS is Tiger
> Is it posible to fix it?
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"Those people who most want to rule people are, ipso-facto, those
least suited to do it."
- A rule of the universe, from the HitchHiker's Guide to the Galaxy
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20070603/c06cdd7e/attachment.html
