[GRASS-user] Some questions
Mon Jun 4 05:32:32 EDT 2007
Martin Besta wrote:
> When I am executing v.overlay (to clip my map with boundary line) I
> recieve always the clipped line (ainput is line, binput is area),
> however I need the polygon. When I switched first and second input
> layer, I had recieved an empty layer.
note features to be considered should have some cat value. (v.category)
> A little problem I have with v.buffer...the output is without attribut
> table.
v.buffer can't transfer the attribute as a new area may be from the
overlap of two original areas with different attributes. (this was
buried in the help page, I've just made it more visible)
> I was trying first v.buffer, then v.db.addtable and finaly v.overaly
> intersect with input line for buffer. But then is the output line
> again.
can you reproduce the effect using the demo spearfish dataset, and post
the command line commands?
> The problem with the spatial dissolve I did with the conversion to
> raster and raster to vector again. Every raster cell has value from
> the attribut (biotop code in my layer) and the conversion to vector
> again dissolved all other lines, only polygons boundaries stay on.
glad you found something that worked; it would be nicer to not need the
conversion from v->r->v of course.
v.distance might help for reconnecting attributes.
Hamish
