[GRASS-user] i.atcor example
massimo di stefano massimodisasha at yahoo.it
Fri Jun 8 05:42:14 EDT 2007
Hi ,
anibody has never used i.actor ?
to  execute the correction on landsat tm7 data,
can i found the needed data  in the " landsat metadata"
(.met / .hdr)
it is possible to reproduce an example using the spearfish data + the
"glcf"
http://glcf.umiacs.umd.edu/index.shtml
landsat tm7  images ?
