[GRASS-user] GRASS-QGIS connection
David Kindem
dkindem at chartermi.net
Wed Jun 13 06:00:31 EDT 2007
Lorenzo,
Thanks to you and the others who responded.
I've commented out the rows where awk is checked, and I can now enter
QGIS from GRASS.
Is there any problem because the software is not locating awk when it
opens QGIS?
Thanks again,
Dave
Dave Kindem
Grand Haven, MI
On Jun 11, 2007, at 5:53 AM, Lorenzo Moretti wrote:
> Hi David
>> Hello,
>> I'm running Lorenzo's binaries (6.2.1) on OS X. I've recently
>> switched my default shell program from tcsh to bash. When I try
>> to launch QGIS from within GRASS, I receive the following:
> Bash shell is required.
> In a new Terminal window enter:
> % env
> and see the result. If you see this row:
> SHELL=/bin/bash
> Bash shell is used and you can use GRASS OS X.
> Or change your default shell inside OS X in two ways:
> Solid way:
> Go to into the NetInfo Manager program (Applications -> Utilities -
> > NetInfo Manager). Click on "users" then find your account. In the
> lower pane is "shell" and see the path. If you see "/bin/tcsh"
> change it to /bin/bash, then quit NetInfo Manager and restart.
> Light way:
> If you don't want to change the NetInfo database entry for your
> account, go to Terminal application (Applications -> Utilities ->
> Terminal) then go to Terminal -> Terminal Preferences and select
> "Execute this command" and make sure it's the shell you want
> (usually is /bin/bash).
> awk is used in many command inside Grass. It's checked at the start
> of script.
> Go to Terminal and in the new window (not inside Grass) enter:
> % which awk
> and see the result. In OS X the path is:
> % /usr/bin/awk
> If you want you can comment the rows where awk is checked ...
> Edit with Text editor the file "/Applications/GrassGIS/Grass6.app/
> Contents/Resources/grass-6.2.1/scripts/d.qgis"
> and comment these rows:
> # Check if we have awk.
> # if [ ! -x "`which awk`" ] ; then
> # echo "$SCRIPT: awk required, please install awk or gawk first"
> 2>&1
> # exit 1
> # fi
> Now restart d.qgis script (Open Qgis application under Xtns menu)
> and select QGIS to run or inside terminal enter:
> ---> GRASS OS X
> GRASS 6.2.1 (location):~ > d.qgis file=/Applications/qgis-0.8.0/
> qgis.app &
> ---> GRASS X11
> qgis.app/Contents/MacOS/qgis &
> Bye
> ______________________________________________________________________
> ____
> || Lorenzo Moretti e-mail: lorenzo.moretti at bologna.enea.it
> ||/|/| ENEA ACS PROTIDR Web: http://wwwamb.bologna.enea.it/
> || | via Don Fiammelli, 2
> ~~~~~~ 40128 BOLOGNA - ITALY Ph: +39-0516098086
> ENEA - Ente Nazionale per le Nuove Tecnologie, l'Energia e l'Ambiente
> ENEA - The Italian Agency for New Technologies, Energy and the
> Environment
> ____
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20070613/bfbc68b8/attachment.html
