[GRASS-user] Problem with v.vol.rst and 3d-interpolation
Stuart Edwards
sedwards2 at cinci.rr.com
Sat Jun 16 12:32:53 EDT 2007
Maybe try adding some 'dummy' data points at the top of the clay
layer and the water table to force the analysis. Try adding a series
of points in the top 1m of the clay (say every 0.1m) with a value of
0.000001 mg/L) and the same in the 1m interval above the water
table. Not very elegant, but it will probably pull the interpolated
values back into the aquifer. Let me know if it works --
Stu
On May 19, 2007, at 10:16 AM, Christian Butzeck wrote:
> Hello!
> I had a (huge) problem with the result of the v.vol.rst interpolation.
> I had some contaminant samples (about 300 values for this sample
> area) from measuring probes, the exact coordinates and the sea
> level (up to 18 for each measuring probes - at different levels).
> First I create a raster map with v.in.ascii from a csv-file with
> all values and coordinates.
> --->v.vol.rst.
> # v.vol.rst input=raster_map_with_values wcolumn=contaminant
> dmin=0.49 segmax=700 npmin=100 elev=test_area tension=10 smooth=0.025
> I used for the region top=29, bottom=0, nsres3=5 and tbres=0.5. The
> level from the probes is located between 1 and 28 meter about sea
> level. For example there could be 5 measurements at one measuring
> probes (e.g. 20.33, 19.83, 19.33, 15.33 about sea level) up to 18
> at one measuring probes (26.11, 25.11, 24.11, 23.11,
> 17.11.........) Just to show that there are no fixed depths for the
> measurements! Maybe its important.!?
> After this I used "r3.mapcalc" to eliminate all values less than
> null and cut the region with a 3d-buffer I created before with
> "r.digit" and "r.to.rast3".
> At last I used "r3.out.vtk" to create a vtk-file for visualization
> with paraview or another 3d-program.
> Now my problem!
> Everything works and looks great on the first moment, but if I
> compare the output data with the original data from the csv-file
> there are big differences. It look likes v.vol.rst interpolates
> with the NULL-values/ No data, even if no (real) value is close to
> these NULL values.
> For example on one measuring probes 10 probes had been taken
> between 13 and 23m about sea level. Above 23m and below 13m there
> are no data (because of no ground water above 23m and a clay bed
> below 12m about sea level!). At 23m there is a concentration from
> 0.01mg/L, at 13m 12.45mg/L (the maximum of the hole area). --------
> > Now I look at the vtk-file and find out, that this maximum is
> located at 0m (7m below the measuring point) about sea level! At
> 23m (the last measuring point) there is a concentration of just 5mg/
> L., the direction of the concentration is right but not the location.
> Can anyone explain me how I can fix this problem. I don't think
> that it's a problem of tension and smooth parameters because I
> tested this since weeks.... If I used the module "v.surf.rst" you
> can choose an anisotropy factor ('theta' and 'scalex'), is it
> possible to use this also at v.vol.rst. For example that the
> interpolation between the vertical values have a higher weighing
> than the horizontal values or the other way around.
> Or is this a bug? - I heard from Soeren, who designed the
> "r3.out.vtk"-module, that there wasn't much time to test this
> software?
> I hope you understand my problem/questions (and my sometimes awful
> English;)
> Regards from Potsdam.
> Christian
> _______________________________________________________________
> SMS schreiben mit WEB.DE FreeMail - einfach, schnell und
> kostenguenstig. Jetzt gleich testen! http://f.web.de/?mc=021192
> grassuser mailing list
> grassuser at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grassuser
