[GRASS-user]Re: Problem with v.vol.rst and 3d-interpolation
butzeck at web.de
butzeck at web.de
Wed Jun 20 04:41:45 EDT 2007
Hello,
I ask Helena and she gave me the anwser. You have to use a parameter "zmult" with v.vol.rst (I try some values between 180 and 10 and choose zmult=50 for my question) . How to use "zmult" is not described in the help until now.
Regards.
> -----Ursprüngliche Nachricht-----
> Von: Stuart Edwards <sedwards2 at cinci.rr.com>
> Gesendet: 16.06.07 18:33:03
> An: Christian Butzeck <butzeck at web.de>
> CC: grassuser at grass.itc.it
> Betreff: Re: [GRASS-user] Problem with v.vol.rst and 3d-interpolation
> Maybe try adding some 'dummy' data points at the top of the clay
> layer and the water table to force the analysis. Try adding a series
> of points in the top 1m of the clay (say every 0.1m) with a value of
> 0.000001 mg/L) and the same in the 1m interval above the water
> table. Not very elegant, but it will probably pull the interpolated
> values back into the aquifer. Let me know if it works --
> Stu
_________________________________________________________________________
In 5 Schritten zur eigenen Homepage. Jetzt Domain sichern und gestalten!
Nur 3,99 EUR/Monat! http://www.maildomain.web.de/?mc=021114
