[GRASS-user] problem with v.patch
Markus Neteler
neteler at itc.it
Sat Jun 23 17:03:36 EDT 2007
Leonardo Lami wrote:
> Hi all,
> I seen a bug in v.patch. If I use two or more simple vectors it works
> well but if I use I see big problem in the topology of the output. This
> in 6.2.1 and in 6.3 version.
> I add a link to a dataset with 2 vectors to make testing.
> www.faunalia.it/download/vpatch.tar.gz
> Thank you
> Leonardo
Leo,
the v.patch manual states
"Any vectors that are duplicated among the maps being patched together
(e.g., border lines) will have to be edited or removed after v.patch is
run.
Such editing can be done automatically using v.clean
(tool=snap,break,rmdupl).
Did you run v.clean?
Markus
View this message in context: http://www.nabble.com/problem-with-v.patch-tf3957155.html#a11270192
Sent from the Grass - Users mailing list archive at Nabble.com.
