[GRASS-user] v.lrs.where users wanted
Markus Neteler neteler at itc.it
Thu Jun 28 09:54:47 EDT 2007
Leonardo Lami wrote on 06/27/2007 12:46 PM:
> lami at faunalia.it ha scritto:
>> Greatings!
>> I will make other tests on the modules in the next days!
>> Hopefully
>> Leonardo
> v.lrs.create works but the output table route_lrs is not linked to any vector. Is it rigth?
Yes. Because LRS knows about it.
>> - v.lrs.label now works (SQL fix in CVS)
> It works but the label route_lrs_labels seems empity. Do you see
> somethings when you load it from GRASS?
You need to use d.label.
Please see v.lrs.label for new example. Currently I recommend to not use
the DBF driver.
>>> - v.lrs.where:
>>>    Then I tested v.lrs.where and discovered that the "offset"
>>>    was reported incorrectly. I have fixed it in CVS but would
>>>    like to ask LRS users to test if it still works ok for you.
>>>    Please let me know.
> It seems work well
Cool.
Markus
ITC -> dall'1 marzo 2007 Fondazione Bruno Kessler
ITC -> since 1 March 2007 Fondazione Bruno Kessler
