[GRASS-user] Having problems with v.in.ogr
Edward Tomlinson
edwardjtomlinson at gmail.com
Fri Jun 29 23:17:49 EDT 2007
Hi
I am having issues importing a shapefile using v.in.ogr
Using basic command v.in.ogr dsn=shapefile layer=shapefile name output=elev
getting the following areas for every entry
GRASS_INFO_WARNING(29..,50..): Area size 6.5e-11, area not imported.
[warning sign] area size 6.5e-11, area not imported
THe shapefile was generated by a Greenstar 2 GPS receiver (John Deere).
There are many columns in the shapefile (30).
How can i limit the number of columns i read in, and how to set which column
is the elevation column (or is ELEVATION okay)?
I am assuming it has something to do with the way the shapefile was
genereated and the precision/length of the numeric fields in the database???
Please can ayone help with this?
Also what is a good .dbf viewer for KDE?
Thanks,
Ed
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20070630/4d6f2bf9/attachment.html
