[GRASS-user] help with ogr2ogr and .shp file
antonio rodriguez
antonio.raju at gmail.com
Thu Mar 1 15:56:50 EST 2007
Hamish escribió:
> antonio rodriguez wrote:
>> I need some help and advice to transform a .shp file to a format
>> readable by GRASS.
> from within your lat lon GRASS location:
> v.in.ogr location=
> to import the shape file and create a new location for it based on its
> .prj projection info. (assuming it has a .prj file. if not you'll have
> to create the needed location manually and import using v.in.ogr from
> within the new location)
>> Extent: (100528.742188, 3991489.250000) - (610083.250000, 4288506.900918)
>> Layer SRS WKT: (unknown)
> Looks like you'll have to create a new location and set the projection
> settings manually...
> then (in the lat/lon location) suck it into the lat/lon projection with
> v.proj.
Dear Hamish, Wolf:
Well, I'll try to be concize. I have an existant location=andal,
mapset=toni with a region:
projection: 3 (Latitude-Longitude)
zone: 0
datum: wgs84
ellipsoid: wgs84
north: 39N
south: 36N
west: 8W
east: 1W
nsres: 0:00:03.6
ewres: 0:00:03.6
rows: 3000
cols: 7000
Within this location and mapset, with v.in.ogr, I have imported the .shp
file into a new location:
v.in.ogr dsn=/home/toni/tmp/hidrografialineal/hs1-1500.shp
out=hidrologia location=hidro
I exit the current session and start a new one with the new parameters:
location=hidro and mapset=PERMANENT:
g.region -p
projection: 0 (x,y)
zone: 0
north: 4288506.90091814
south: 3991489.25
west: 100528.7421875
east: 610083.25
nsres: 14850.88254591
ewres: 25477.72539063
rows: 20
cols: 20
Everything is OK. I exit this session and start the first one (the one
where I want to import the hidrologia vector file)
So in location=andal, mapset=toni I do
v.proj input=hidrologia location=hidro mapset=PERMANENT output=hidrologia
And I get:
PROJ_INFO and PROJ_UNITS files not found for location hidro
Where do I get this files? How do I create it?
TIA
Antonio
> Hamish
