[GRASS-user] help with ogr2ogr and .shp file
WolfgangZ
wollez at gmx.net
Thu Mar 1 16:05:54 EST 2007
Hi Antonio,
you need a real location for hidro, not only a x,y location! I hope you
know in which coordinate system your shapefile is? So, you have to build
a location for that specific coordinate system! Then v.proj will find
the transformation parameters.
Wolfgang
antonio rodriguez schrieb:
> Hamish escribió:
>> antonio rodriguez wrote:
>>> I need some help and advice to transform a .shp file to a format
>>> readable by GRASS.
>> from within your lat lon GRASS location:
>> v.in.ogr location=
>> to import the shape file and create a new location for it based on its
>> .prj projection info. (assuming it has a .prj file. if not you'll have
>> to create the needed location manually and import using v.in.ogr from
>> within the new location)
>>> Extent: (100528.742188, 3991489.250000) - (610083.250000,
>>> 4288506.900918)
>>> Layer SRS WKT: (unknown)
>> Looks like you'll have to create a new location and set the projection
>> settings manually...
>> then (in the lat/lon location) suck it into the lat/lon projection with
>> v.proj.
> Dear Hamish, Wolf:
> Well, I'll try to be concize. I have an existant location=andal,
> mapset=toni with a region:
> projection: 3 (Latitude-Longitude)
> zone: 0
> datum: wgs84
> ellipsoid: wgs84
> north: 39N
> south: 36N
> west: 8W
> east: 1W
> nsres: 0:00:03.6
> ewres: 0:00:03.6
> rows: 3000
> cols: 7000
> Within this location and mapset, with v.in.ogr, I have imported the .shp
> file into a new location:
> v.in.ogr dsn=/home/toni/tmp/hidrografialineal/hs1-1500.shp
> out=hidrologia location=hidro
> I exit the current session and start a new one with the new parameters:
> location=hidro and mapset=PERMANENT:
> g.region -p
> projection: 0 (x,y)
> zone: 0
> north: 4288506.90091814
> south: 3991489.25
> west: 100528.7421875
> east: 610083.25
> nsres: 14850.88254591
> ewres: 25477.72539063
> rows: 20
> cols: 20
> Everything is OK. I exit this session and start the first one (the one
> where I want to import the hidrologia vector file)
> So in location=andal, mapset=toni I do
> v.proj input=hidrologia location=hidro mapset=PERMANENT output=hidrologia
> And I get:
> PROJ_INFO and PROJ_UNITS files not found for location hidro
> Where do I get this files? How do I create it?
> TIA
> Antonio
>> Hamish
> grassuser mailing list
> grassuser at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grassuser
