[GRASS-user] help with ogr2ogr and .shp file
antonio rodriguez antonio.raju at gmail.com
Fri Mar 2 03:48:41 EST 2007
WolfgangZ escribió:
> Hi Antonio,
> you need a real location for hidro, not only a x,y location! I hope
> you know in which coordinate system your shapefile is? So, you have to
> build a location for that specific coordinate system! Then v.proj will
> find the transformation parameters.
> Wolfgang
Hi Wolfgang,
I got it! I created a new location from scratch and then import with
v.in.ogr.
Thanks!
Antonio
> antonio rodriguez schrieb:
>> Hamish escribió:
>>> antonio rodriguez wrote:
>>>> I need some help and advice to transform a .shp file to a format
>>>> readable by GRASS.
>>> from within your lat lon GRASS location:
>>> v.in.ogr location=
>>> to import the shape file and create a new location for it based on its
>>> .prj projection info. (assuming it has a .prj file. if not you'll have
>>> to create the needed location manually and import using v.in.ogr from
>>> within the new location)
>>>> Extent: (100528.742188, 3991489.250000) - (610083.250000,
>>>> 4288506.900918)
>>>> Layer SRS WKT: (unknown)
>>> Looks like you'll have to create a new location and set the projection
>>> settings manually...
>>> then (in the lat/lon location) suck it into the lat/lon projection with
>>> v.proj.
>> Dear Hamish, Wolf:
>> Well, I'll try to be concize. I have an existant location=andal,
>> mapset=toni with a region:
>> projection: 3 (Latitude-Longitude)
>> zone:       0
>> datum:      wgs84
>> ellipsoid:  wgs84
>> north:      39N
>> south:      36N
>> west:       8W
>> east:       1W
>> nsres:      0:00:03.6
>> ewres:      0:00:03.6
>> rows:       3000
>> cols:       7000
>> Within this location and mapset, with v.in.ogr, I have imported the
>> .shp file into a new location:
>> v.in.ogr dsn=/home/toni/tmp/hidrografialineal/hs1-1500.shp
>> out=hidrologia location=hidro
>> I exit the current session and start a new one with the new parameters:
>> location=hidro and mapset=PERMANENT:
>> g.region -p
>> projection: 0 (x,y)
>> zone:       0
>> north:      4288506.90091814
>> south:      3991489.25
>> west:       100528.7421875
>> east:       610083.25
>> nsres:      14850.88254591
>> ewres:      25477.72539063
>> rows:       20
>> cols:       20
>> Everything is OK. I exit this session and start the first one (the
>> one where I want to import the hidrologia vector file)
>> So in location=andal, mapset=toni I do
>> v.proj input=hidrologia location=hidro mapset=PERMANENT
>> output=hidrologia
>> And I get:
>> PROJ_INFO  and PROJ_UNITS files not found for location hidro
>> Where do I get this files? How do I create it?
>> TIA
>> Antonio
>>> Hamish
>> grassuser mailing list
>> grassuser at grass.itc.it
>> http://grass.itc.it/mailman/listinfo/grassuser
