[GRASS-user] Spatial Statistics
Glynn Clements
glynn at gclements.plus.com
Fri Mar 9 02:48:39 EST 2007
Dr. Manuel Seeger wrote:
> > I have fixed that - "let" is a bash command but not shell.
> > Change line 96 (where the "let" is) to
> > n=`expr $n + 1`
> I changed this in v.db.addcol and it behaves somehow strange, but now it
> works....:
> it creates the table, it seems to calculate right, but gives this echo:
> Adding column <dgm_n>
> [: 96: expr 1+1: bad number
You must have spaces around the "+" sign:
$ expr 1 + 1
2
$ expr 1+1
1+1
