[GRASS-user] A color rules - a little issue
Jachym Cepicky
jachym.cepicky at gmail.com
Mon Mar 19 10:30:47 EDT 2007
imho this could be reason for $HOME/.grass6/7 directory
also configuration files from r.li should go there..
we would need set of functions, which whould identify & open the
configuration files, if they would exist...
what do you think, developers?
jachym
2007/3/19, Jarosław Jasiewicz <jarekj at amu.edu.pl>:
> Hi
> I have a suggestion about color managment in grass
> I just work on couple of maps where I need to prepare custom color
> schemes (rules). Using the r.colors.rules is slighty (Hmm... rather
> strongly) uncomfortable.
> To omit it I replaced dir colors in ../grass63.cvs/etc/ dir with simlink
> to dir in my home directory and I create new rule file every time I must
> experiment with colors.
> It is not good solution for two reason:
> 1) every new grass complilation makes problem with symlink
> 2) I have over 60 rules files in one directory and the number increase
> Is possible to create solution similar to r.reclass.file to use custom
> color rule file from anywhere in file system?
> regards
> Jarek
> grassuser mailing list
> grassuser at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grassuser
Jachym Cepicky
e-mail: jachym.cepicky gmail com
URL: http://les-ejk.cz
GPG: http://www.les-ejk.cz/pgp/jachym_cepicky-gpg.pub
