[GRASS-user] project units vs. imported image units ?
Glynn Clements
glynn at gclements.plus.com
Tue Mar 20 16:09:59 EDT 2007
Ricardo Oliveira wrote:
> I need to create a project that has 10x8 meters. Also, i need to
> import tiff images to the project but i don`t have the tfw
> files...so when i import the image the unit that is considered is
> the amount of pixels...and the image is clearly outside my working
> area.
> Is there a way to give known coordinates to the 4 corners of the
> image when importing them so that GRASS puts them on the correct
> position.
You can use r.region to set a map's bounds.
