[GRASS-user] Grass 6.3 on OS X
Richard Chirgwin
rchirgwin at ozemail.com.au
Wed Mar 21 16:42:42 EDT 2007
In using the William Kyngesburye build on Mac OS X, I have a persistent
problem with vector files. Even where I have built the vector inside
Grass (for eg, by importing a shapefile such as the outline of
Australia), there is a coor file problem. Step by step:
1) Start Grass
2) Import shapefile
3) Select new vector file
4) Display - OK.
5) Exit Grass
6) Restart Grass
7) Select vector file
8) Display
At (8), Grass says the Coor files is larger than it should be, and asks
me to rebuild the topology. It will not display the file. V.build
doesn't fix the problem.
Any suggestions?
Richard Chirgwin
