[GRASS-user] Grass 6.3 on OS X
Michael Barton
michael.barton at asu.edu
Thu Mar 22 01:12:15 EDT 2007
I think this is another example of an issue importing certain shapefiles via
OGR. There has been a thread discussing this on this list over the past few
days. I didn't follow it closely, but you need to set one of the flags
(don't create topology??).
Michael
On 3/21/07 1:42 PM, "Richard Chirgwin" <rchirgwin at ozemail.com.au> wrote:
> Hi,
> In using the William Kyngesburye build on Mac OS X, I have a persistent
> problem with vector files. Even where I have built the vector inside
> Grass (for eg, by importing a shapefile such as the outline of
> Australia), there is a coor file problem. Step by step:
> 1) Start Grass
> 2) Import shapefile
> 3) Select new vector file
> 4) Display - OK.
> 5) Exit Grass
> 6) Restart Grass
> 7) Select vector file
> 8) Display
> At (8), Grass says the Coor files is larger than it should be, and asks
> me to rebuild the topology. It will not display the file. V.build
> doesn't fix the problem.
> Any suggestions?
> Richard Chirgwin
Michael Barton, Professor of Anthropology
School of Human Evolution & Social Change
Center for Social Dynamics & Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
