[GRASS-user] Problem with slope modeling .
Radomir
dod.mort at gmail.com
Sun Mar 25 11:12:00 EDT 2007
Dnia 25-03-2007, nie o godzinie 07:35 +0530, nishith datta napisaĆ(a):
> hi Radomir,
> I found a nice write up on interpolation techniques GIS Ostrava
> 2006.htm. If you cant find let me know shall send you attachment.
> May be it will help you solve the problem.
> Keep us posted about the results and how you resolve the problem
> thanks
> nishith
> On 3/25/07, Radomir <dod.mort at gmail.com> wrote:
> Hi all,
> I'm preparing the slope and elevation map from digitised
> isolines.
> I'm using v.surf.rst to do that with the following options:
> v.surf.rst input="izolinie_punkty" layer=1
> zcolumn="wysokosc_m_npm"
> dmax=3.174812 dmin=0.634962 elev="mapa_wystaw"
> slope="mapa_spadk"
> maskmap="maska" zmult=1.0 tension=40. segmax=40 npmin=300
> The screenshot from small part of resulting map is here:
> http://mort.no-ip.org/screen.png
> On this screen you can see the valley in the center. I expect
> that the
> slope between two isolines on the bottom of the valley will be
> similar.
> But it is changing and gives an effect of "wave" between
> isolines. Those
> "waves" cause the unexpected results in LS factor.
> I was trying to manipulate with the tension and smoothness but
> without
> visible results.
> What should I change to calculate better slope model?? Any
> help with
> understanding will be appreciated.
> Best Regards,
> Radomir
> Radomir
> The Future Is Now ;)
> grassuser mailing list
> grassuser at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grassuser
hi Nishit
Unfortunately I can't find the website from your link.
If you please send me again this link...
Best regards,
Radomir
Radomir
