[GRASS-user] Integrating multi tables
Moritz Lennert
mlennert at club.worldonline.be
Mon Mar 26 04:50:13 EDT 2007
On 24/03/07 07:34, Richard Chirgwin wrote:
> Trying to work this one out, and not getting anywhere!
> I have imported Shapefiles into vector maps.
> I have "population" data (not people but using the same cat column IDs
> as in the shapefile attribute tables).
> How do I integrate the population data so that the shapefiles can be
> coloured in thematic maps?
> I can add columns to the vector attribute tables - but I can't find a
> command that would mass-populate the column
> (in MySQL it would be a simple UPDATE Table 1, Table 2 set column=column
> where table 1.cat=table 2.cat).
> (It probably doesn't help that the population data is in MySQL but I am
> happy to import)
> I fear that I am missing something *really* simple but am just about
> going spare trying to find out!
If you are using the default GRASS settings, your shapefile data gets
imported as a dbf file. There is no way of combining this file with
others, either in a database application or in GRASS (i.e. there is no
equivalent of ArcView's "joining" tables).
However, you are not obliged to work with dbf files, you can import your
shapefile attribute data into mysql and then either add the colums with
your above 'update' command or just create a view combining the two
tables and link your map to this view.
Use:
- db.connect to define a different database backend (Databases->Manage
Databases->Connect to database in the GUI)
- db.copy to copy an existing table to another table, including between
different backends, i.e. dbf to mysql (Databases->Manage Databases->Copy
table)
- v.db.connect to link your map to the table or to the view
(Vector->vector<->database connection->Set database connection...)
You can also begin by setting db.connect in a new location, and then
import the shapefile with v.in.ogr. The attribute table is then
automatically created in the database you connected to.
Moritz
