[GRASS-user] some hints for grass 6.3, now on etch !
Raffaele Morelli
raffaele.morelli at gmail.com
Tue Mar 27 10:48:31 EDT 2007
> Welcome to GRASS 6.3.cvs (2007)
> GRASS homepage: http://grass.itc.it/
> This version running thru: Bash Shell (/bin/bash)
> Help is available with the command: g.manual -i
> See the licence terms with: g.version -c
> If required, restart the graphical user interface with: gis.m
> When ready to quit enter: exit
> GRASS 6.3.cvs (goettingen):/usr/include/X11 > couldn't execute
> "g.region": no such file or directory
> after some tries i realized a second install of grass 6.2.1 and this
> starts right. after remove this via apt-get
> make clean and make distclean new running of .configure and again make
> (and make install)
> no success.
> gis.m fails.
> starting a single Monitor and displaying some stuff is no problem.
> any idea to find a reason?
what about gdal installation? it seems that grass is not linked to libgdal.
if gdal library is installed you need to add the path to libgdal library to
your ld.so.conf and run ldconfig.
raffaele
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20070327/e70ba3d1/attachment.html
