[Fwd: Re: [GRASS-user] some hints for grass 6.3, now on etch !]
Ricardo Oliveira
autopilot at oniduo.pt
Tue Mar 27 15:03:23 EDT 2007
How have you used "./configure" or how have you compiled from source?
I have grass 6.3.x and everything is working...
Ricardo
On Tue, 27 Mar 2007 17:20:50 +0200
"Georg Lösel (privat)" <georg at de-schorsch.de> wrote:
> -----BEGIN PGP SIGNED MESSAGE-----
> Hash: SHA1
> Hi,
> > what about gdal installation? it seems that grass is not linked to
> > libgdal. if gdal library is installed you need to add the path to
> > libgdal library to your ld.so.conf and run ldconfig.
> thanks, but no success,
> locate gdal
> /usr/lib/libgdal1.3.2.so.1
> /usr/lib/libgdal1.3.2.so.1.10.0
> then:
> denkbrett:/home/georg# locate ld.so.conf
> /etc/ld.so.conf
> /etc/ld.so.conf.d
> /etc/ld.so.conf.d/i486-linux-gnu.conf
> ld.so.conf is linked to /etc/ld.so.conf.d and in this directory is
> this after my changes
> I /etc/ld.so.conf.d/i486-linux-gnu.conf
> Row 1 Col 1 5:19 Ctrl-K H for help
> # Multiarch support
> /lib/i486-linux-gnu
> /usr/lib/i486-linux-gnu
> then ldconfig
> and then grass63
> same error
> Georg
> Georg Lösel
> Meterstraße 37
> 30169 Hannover
> fon/fax: ++49 (0) 511 - 80 60 685
> mobil: ++49 (0) 176 - 233 244 11
> mail: georg at de-schorsch.de
> skype/wengo: georgloesel
> internet: www.de-schorsch.de
> LatLon: 52,3625; 9,7481
> gpg: look for 05C6733F
> -----BEGIN PGP SIGNATURE-----
> Version: GnuPG v1.4.6 (GNU/Linux)
> Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
> iD8DBQFGCTZSOXEppwXGcz8RAlqrAJ9A+3sKCublU6dfcjDIsyb4L/WG+ACeOBSa
> bJQ3n2yEFwkZ9HWOMr0eYoc=
> =poEx
> -----END PGP SIGNATURE-----
> grassuser mailing list
> grassuser at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grassuser
