[Fwd: Re: [GRASS-user] some hints for grass 6.3, now on etch
Glynn Clements
glynn at gclements.plus.com
Tue Mar 27 16:59:32 EDT 2007
"Georg Lösel (privat)" wrote:
> > what about gdal installation? it seems that grass is not linked to libgdal.
> > if gdal library is installed you need to add the path to libgdal library to
> > your ld.so.conf and run ldconfig.
> thanks, but no success,
> locate gdal
> /usr/lib/libgdal1.3.2.so.1
> /usr/lib/libgdal1.3.2.so.1.10.0
GRASS is probably linked to a GDAL library with a different name, e.g.
libgdal.so.1.
Creating a symlink with the correct name (then re-running ldconfig)
may work. Running ldd on r.in.gdal should provide the name which GRASS
is using to refer to the GDAL library.
