[Fwd: Re: [GRASS-user] some hints for grass 6.3, now on etch !]
    Raffaele Morelli
    raffaele.morelli at gmail.com
    Wed Mar 28 06:26:04 EDT 2007
> I    /etc/ld.so.conf.d/i486-linux-gnu.conf
> Row 1    Col 1    5:19  Ctrl-K H for help
> # Multiarch support
> /lib/i486-linux-gnu
> /usr/lib/i486-linux-gnu
> /usr/lib/libgdal1.3.2.so.1
> /usr/lib/libgdal1.3.2.so.1.10.0
> then ldconfig
> and then grass63
> same error
No library name is needed in the path-to-gdal, so only '/usr/lib' must
appear instead of the last two lines.
If you compiled from source using only ./configure without options and
libgdal comes as debian package you need to install libgdal-1.3.2-dev (in
order to get library headers, *.h files) and use --with-gdal  option (look
at './configure --help' ).
Other dev packages are needed to compile from source,
http://hamish.bowman.googlepages.com/debiangisfiles#compile
this is for 6.1 but dev packages are the same.
raffaele
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20070328/23409697/attachment.html
