[GRASS-user] problem with v.edit tool=merge
Jarek Jasiewicz
jarekj at amu.edu.pl
Thu Mar 29 01:55:27 EDT 2007
Martin Landa napisał(a):
> Hi Jarek,
> 2007/3/28, Jarek Jasiewicz <jarekj at amu.edu.pl>:
>> - it sometimes work, but new line has two categories on one layer, it is
>> corrected? IMHO it is not the best solution
> sometimes?;-)
I made several test on that file some lines have merged, but I can't say
why that ones
> yes, it is not the best solution, but I am not sure what the user
> would expect, what do you thing? Merging two lines (layer 1) described
> bellow:
> +-----1/1-----+------1/2-----+
> we get new line
> +------1/?------+
> I think that the vector layer should not be changed (i.e. still layer 1).
> Currently this line gets category 1 and 2.
I think that tool is suitable to work on fresh vector (for example after
r.to.vect) without atributies it will rather be a part of the sript than
stand-alone tool,
maybe other grass-user will help which solution will be the best
>> - I did not reproduced merge in file i send. It has only worked when i
>> used cat=1-99999 (i.e only 2 or three lines has been merged)
>> - but if i used cat 1-99 it hasen't worked, no line has been merged
> I am not sure if I understand well, using your testing data
> cat=1-99999 and cat=1-99 works OK.
no, in that situation cat=1-99 gave negative result (no lines merged)
but cat=1-99999 merged two or three lines
>> - there is no problem with merging if there are only two lines in map
if I prepared few vector with only two lines the result was OK
>> - if two lines has been merged and line with cat=1/2 has been created,
in some situations in file where were more than two lines with huge
threshold first two lines, but no more lines can be merged again
Jarek
