[GRASS-user] problem with v.edit tool=merge
Martin Landa landa.martin at gmail.com
Wed Mar 28 16:39:26 EDT 2007
Hi Jarek,
2007/3/28, Jarek Jasiewicz <jarekj at amu.edu.pl>:
> - it sometimes work, but new line has two categories on one layer, it is
> corrected? IMHO it is not the best solution
sometimes?;-)
yes, it is not the best solution, but I am not sure what the user
would expect, what do you thing? Merging two lines (layer 1) described
bellow:
+-----1/1-----+------1/2-----+
we get new line
+------1/?------+
I think that the vector layer should not be changed (i.e. still layer 1).
Currently this line gets category 1 and 2.
> - I did not reproduced merge in file i send. It has only worked when i
> used cat=1-99999 (i.e only 2 or three lines has been merged)
> - but if i used cat 1-99 it hasen't worked, no line has been merged
I am not sure if I understand well, using your testing data
cat=1-99999 and cat=1-99 works OK.
> - there is no problem with merging if there are only two lines in map
> - if two lines has been merged and line with cat=1/2 has been created,
> no merge can be done in spite on cat an thre values
> that all i found till now
Once again, I am not sure if I understand well.
Martin
> what means: lines l have not any joint node is there some restriction on
> lines?
>  >BTW I committed some minor fixes in v.edit tool=merge (printing number
>  >of  merged lines). So you should run `cvs update` and recompile it.
>  >Sorry, v.edit module is relatively new/under development. In any case
>  >it is great there is the user who is testing/using v.edit;-)
> yes, I know it is new tool, I not expected it will be work at once.
> IMHO it is very powerful tool. Grass had need it
> best wishes in future development, i promise I will be testing it
> Jarek
Martin Landa <landa.martin at gmail.com> * http://gama.fsv.cvut.cz/~landa *
