[GRASS-user] Error updating GRASS
Jachym Cepicky
jachym.cepicky at gmail.com
Thu Mar 29 10:59:21 EDT 2007
the file seems to be ok.
I greped around
cd $GISBASE/etc/gui/
grep upvar gm/*
and did not found anything useful. Unfortunately, I do not have my
laptop here, so I can not check the sources now to see, if everything
is all right.
Could anybody from the Tcl-masters have a look at the problem?
Thanks a lot
Jachym
2007/3/29, Jachym Cepicky <jachym.cepicky at gmail.com>:
> hi, nobody else reported such problem...
> are u using tcltk 8.4?
> could you sent me /usr/lib/grass/etc/gm/gm.tcl ?
> jachym
> 2007/3/29, António G Rodrigues <agrodrigues at ipt.pt>:
> > Hi folks,
> > I apdated to grass6.2 in my ubuntu system using the repositories in...
> > deb http://les-ejk.cz/ubuntu edgy multiverse
> > deb-src http://les-ejk.cz/ubuntu edgy multiverse
> > The problem is that when opening grass it crashes everytime. The error message is:
> > GRASS 6.2.1 (Europe):~ > Error in startup script: bad variable name "coords(1)": upvar won't create a scalar variable that looks like an array element
> > while executing
> > "global coords($mon)"
> > (procedure "MapCanvas::pointer" line 5)
> > invoked from within
> > "MapCanvas::pointer $mon"
> > (procedure "MapCanvas::create" line 226)
> > invoked from within
> > "MapCanvas::create"
> > (procedure "Gm::startmon" line 11)
> > invoked from within
> > "Gm::startmon"
> > (procedure "Gm::create" line 69)
> > invoked from within
> > "Gm::create"
> > (procedure "main" line 30)
> > invoked from within
> > "main $argc $argv"
> > (file "/usr/lib/grass/etc/gm/gm.tcl" line 521)
> > Any clues?
> > Thanks in advance,
> > António
> > grassuser mailing list
> > grassuser at grass.itc.it
> > http://grass.itc.it/mailman/listinfo/grassuser
> Jachym Cepicky
> e-mail: jachym.cepicky gmail com
> URL: http://les-ejk.cz
> GPG: http://www.les-ejk.cz/pgp/jachym_cepicky-gpg.pub
Jachym Cepicky
