[GRASS-user] grass cvs libgdal startup problem
    Francesco Mirabella
    mirabell at unipg.it
    Thu May  3 08:49:11 EDT 2007
Hi Glynn,
many thanks for your very quick reply, that worked fine.
cheers
Francesco
On Thu, May 03, 2007 at 12:38:38PM +0100, Glynn Clements wrote:
> Francesco Mirabella wrote:
> > ok, I have installed gdal from source and I got "gdal support" ok
> > after the configure. However, when starting grass, after a new
> > location was created the main window appears for a second, then
> > crashes and I get:
> > "child process exited abnormally"
> > -> If I try d.m command I get:
> > Error in startup script: ps.map: error while loading shared libraries:
> > libgdal.so.1: cannot open shared object file: No such file or directory
> Add the directory where libgdal.so.1 resides to the file
> /etc/ld.so.conf, then run ldconfig.
> Glynn Clements <glynn at gclements.plus.com>
