[GRASS-user] grass cvs libgdal startup problem
Glynn Clements
glynn at gclements.plus.com
Thu May 3 07:38:38 EDT 2007
Francesco Mirabella wrote:
> ok, I have installed gdal from source and I got "gdal support" ok
> after the configure. However, when starting grass, after a new
> location was created the main window appears for a second, then
> crashes and I get:
> "child process exited abnormally"
> -> If I try d.m command I get:
> Error in startup script: ps.map: error while loading shared libraries:
> libgdal.so.1: cannot open shared object file: No such file or directory
Add the directory where libgdal.so.1 resides to the file
/etc/ld.so.conf, then run ldconfig.
