[GRASS-user] r.out.gdal not working
Tom Russo
russo at bogodyn.org
Sun May 6 13:31:19 EDT 2007
On Sun, May 06, 2007 at 03:54:34PM +0100, we recorded a bogon-computron collision of the <glynn at gclements.plus.com> flavor, containing:
> This probably means that the GDAL library was built without GRASS
> support. This is quite common, as GRASS is one of the harder options
> to support. GRASS itself requires GDAL, so building a version of GDAL
> which supports GRASS involves first building GDAL without GRASS
> support, then building GRASS, then building GDAL again with GRASS
> support.
Isn't the gdal-grass plugin still the preferred way to get GRASS support into
gdal? The "build gdal without grass, build grass, rebuild gdal" thing is a
real PITA, and the plugin is much easier.
I haven't upgraded GDAL since 1.3.2, though --- does the plugin still work
with GDAL 1.4.0?
Tom Russo KM5VY SAR502 DM64ux http://www.swcp.com/~russo/
Tijeras, NM QRPL#1592 K2#398 SOC#236 AHTB#1 http://kevan.org/brain.cgi?DDTNM
"And, isn't sanity really just a one-trick pony anyway? I mean all you get is
one trick, rational thinking, but when you're good and crazy, oooh, oooh,
oooh, the sky is the limit!" --- The Tick
