[GRASS-user] Again: Problem with WMS-Services
Christian Braun
christian.braun at tudor.lu
Mon May 7 11:00:23 EDT 2007
Hi list members,
I wrote to the list a few weeks ago with no answers to my problem.
So again here is my problem again:
I have a problem importing WMS-Services into GRASS. Here is the command
and the description of the error I got:
##The command which has been issued on grass command line
r.in.wms -d -p output=DEM_WMS
mapserver=http://10.3.1.12/cgi-bin/mapserv?map=/data/umn/pmapper-3.0.1/config/default/demo_wms.map
layers=DEM_WMS srs=EPSG:4326 format=geotiff wmsquery=version=1.1.1
maxcols=1024 maxrows=1024 folder=/home/uleopold/tmp 'wgetoptions=-c -t 5
--user-agent=MSIE5.5' method=nearest v=1 --overwrite
##The error message:
wms.download 'requestfile=/home/uleopold/tmp/DEM_WMS_.wget'
'wgetoptions=-c -t 5 --user-agent=MSIE5.5'
Downloading tiles
cat: /home/uleopold/tmp/DEM_WMS_.wget: No such file or directory
All tiles downloaded successfully
r.in.gdalwarp -c -p 'output=DEM_WMS' 'method=nearest' 's_srs=EPSG:4326'
ERROR: Required parameter <input> not set:
(Raster file or files to be imported. If multiple files are
specified they will be patched together.).
In software like QGIS and ArcGIS the WMS-Service is working very well.
It seems that there is aproblem with the input data that is piped to
gdalwarp.
Any ideas...?
cheers
Christian
