[GRASSLIST:1203] Re: [GRASS-user] d.rast
    Jochen gaedcke
    gaedcke at web.de
    Thu May 10 05:07:22 EDT 2007
dear nisith,
sorry, I did not mention this is a 6.3 problem. 6.2 works fine.
If I start a monitor before I get a memory access error.
cheers, Jochen
Am Donnerstag, 10. Mai 2007 05:16 schrieb nishith datta:
> hi  jochen,
> Do we assume you have started a monitor with *d.mon start=x0* or *d.mon x0,
> *before trying
> to open the map in the display. X0 is the active monitor where you want the
> display to appear.Replace with a suitable monitor upto x7, as reqd.
> At least your error , no socket to connect to suggest that the monitor is
> not open.
> Thanks
> nishith
