[GRASS-user] gdal - r.in.onearth
Tomas Lanczos lanczos at t-zones.sk
Thu May 10 06:00:11 EDT 2007
I tried to download some landsat7 pictures by r.in.onearth, but I got
the following errormessage (see the end of the message).
Should I recompile the gdal (if yes, whitch option used) or any other
workarounds proposed?
Thank You
Tomas
p.s.: using Grass 6.3.CVS and 6.2.1 on Ubuntu Feisty Fawn
Downloaded file is not a GeoTiff file, but will try to import
************** CHECK DATA *****************
ERROR 4:
`/home/tomas/grassdata/Slovakia/PERMANENT/.tmp/thor/20010.0/Image_global_mosaic_base_visual__'
not recognised as a supported file format.
GDALOpen failed - 4
ERROR 4:
GDALOpen failed - 4
!-------------------BREAK---------------------!
Downloaded file is not supported by gdal, or cannot be imported
File of Type:  "        XML
Message from Server http://wms.jpl.nasa.gov/wms.cgi
!------------BEGIN-ERROR-MESSGAE--------------!
<?xml version='1.0' encoding="UTF-8" standalone="no" ?>
<!DOCTYPE ServiceExceptionReport SYSTEM
"http://www.digitalearth.gov/wmt/xml/exception_1_1_0.dtd ">
<ServiceExceptionReport version="1.1.0">
   <ServiceException>
     Bounding box has an invalid area
   </ServiceException>
</ServiceExceptionReport>
!-------------END-ERROR-MESSGAE---------------!
Finished
