[GRASS-user] gdal - r.in.onearth
Thu May 10 08:53:21 EDT 2007
Tomas Lanczos wrote:
> I tried to download some landsat7 pictures by r.in.onearth, but I got
> the following errormessage (see the end of the message).
> Should I recompile the gdal (if yes, whitch option used) or any other
> workarounds proposed?
> p.s.: using Grass 6.3.CVS and 6.2.1 on Ubuntu Feisty Fawn
> Downloaded file is not a GeoTiff file, but will try to import
> ************** CHECK DATA *****************
> ERROR 4:
> `/home/tomas/grassdata/Slovakia/PERMANENT/.tmp/thor/20010.0/Image_glo
> bal_mosaic_base_visual__'  not recognised as a supported file format.
At least $HEIGHT and $WIDTH are missing from the name of the file.
They are set by `g.region -gb` rows,cols.
but for me (spearfish) that gives:
G63> g.region -b
pj_transform() failed
cause: failed to load NAD27-83 correction file
ERROR: Error in pj_do_proj (projection of input coordinate pair)
that doesn't look good.
do you see the same?
maybe something to do with g.region/cmd/printwindow.c Rev 2.20+
 http://freegis.org/cgi-bin/viewcvs.cgi/grass6/general/g.region/cmd/printwindow.c
you say it fails with 6.2.1? that was before those changes.
for me it fails in 6.3-cvs in the same way (due to g.region bug), and
works in 6.2.1.
Ubuntu: try changing the first line of the script to #!/bin/bash
Hamish
