[GRASS-user] which version of GRASS should I choose to install in
a Suse 10.2 i386 version ?
Raymond Fu
raymond_fu at yahoo.com
Mon May 14 06:07:52 EDT 2007
hi Markus,Stephan,
Thanks, it can proceed installation of first few files as stated in readme file. However when grass-6.2.1-1suse10.2.i586.rpm is installed, it returns below error? How can I proceed the installation? Do I need to install certain extra file first?
linux-s3qw:~/Desktop/GRASS# rpm -Uhv grass-6.2.1-1suse10.2.i586.rpm
error: Failed dependencies:
unixODBC is needed by grass-6.2.1-1suse10.2.i586
fftw3 is needed by grass-6.2.1-1suse10.2.i586
libfftw3.so.3 is needed by grass-6.2.1-1suse10.2.i586
libmysqlclient.so.15 is needed by grass-6.2.1-1suse10.2.i586
libmysqlclient.so.15(libmysqlclient_15) is needed by grass-6.2.1-1suse10.2.i586
libodbc.so.1 is needed by grass-6.2.1-1suse10.2.i586
Thanks,
Raymond
Stephan Holl <stephan.holl at intevation.de> wrote: Hello Raymond,
Raymond Fu , [20070511-17:28:04]:
> Thanks. However when I run the installation, it returns errors as
> belows. How can I proceed the installation? Did I miss certain
> settings?
> OSS at linux-s3qw:~/Desktop/Work/OpenSource/GRASS/SuseV10.2> rpm -Uhv
> geos-2.2.3-1suse10.2.i586.rpm error: can't create transaction lock
> on /var/lib/rpm/__db.000
You need to be root to install RPM-packages. This should cure the above
behaviour.
Best
Stephan
Stephan Holl , http://intevation.de/~stephan
Tel: +49 (0)541-33 50 8 32 | Intevation GmbH | AG Osnabrück - HR B 18998
Geschäftsführer: Frank Koormann, Bernhard Reiter, Dr. Jan-Oliver Wagner
Send instant messages to your online friends http://uk.messenger.yahoo.com
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20070514/0b2cf20e/attachment.html
