[GRASS-user] which version of GRASS should I choose to install in a Suse 10.2 i386 version ?
Stephan Holl stephan.holl at intevation.de
Mon May 14 06:13:49 EDT 2007
Hello Raymond,
Raymond Fu <raymond_fu at yahoo.com>, [20070514 - 18:07:52]
> hi Markus,Stephan,
> Thanks, it can proceed installation of first few files as stated in
> readme file.  However when  grass-6.2.1-1suse10.2.i586.rpm is
> installed, it returns below error?   How can I proceed the
> installation?   Do I need to install certain extra file first?
> linux-s3qw:~/Desktop/GRASS# rpm -Uhv grass-6.2.1-1suse10.2.i586.rpm
> error: Failed dependencies:
>         unixODBC is needed by grass-6.2.1-1suse10.2.i586
>         fftw3 is needed by grass-6.2.1-1suse10.2.i586
>         libfftw3.so.3 is needed by grass-6.2.1-1suse10.2.i586
>         libmysqlclient.so.15 is needed by grass-6.2.1-1suse10.2.i586
>         libmysqlclient.so.15(libmysqlclient_15) is needed by
> grass-6.2.1-1suse10.2.i586 libodbc.so.1 is needed by
These files need to be installes using your suse-installer called yast.
After that, you need to do:
This should work then.
Best
	Stephan
Stephan Holl <stephan.holl at intevation.de>, http://intevation.de/~stephan
Tel: +49 (0)541-33 50 8 32 | Intevation GmbH | AG Osnabrück - HR B 18998
Geschäftsführer:  Frank Koormann, Bernhard Reiter, Dr. Jan-Oliver Wagner
