[GRASS-user] which version of GRASS should I choose to install in
a Suse 10.2 i386 version ?
Raymond Fu
raymond_fu at yahoo.com
Wed May 16 06:32:37 EDT 2007
thanks. I can download all of the dependent file except libmysqlclient.so.15. I am using YAST to download (software-> add-on product). But it need me to tell the server. How should I input? or am I doing in the right way?
Thank a lot.
Raymond
Stephan Holl <stephan.holl at intevation.de> wrote: Hello Raymond,
Raymond Fu , [20070514 - 18:07:52]
> hi Markus,Stephan,
> Thanks, it can proceed installation of first few files as stated in
> readme file. However when grass-6.2.1-1suse10.2.i586.rpm is
> installed, it returns below error? How can I proceed the
> installation? Do I need to install certain extra file first?
> linux-s3qw:~/Desktop/GRASS# rpm -Uhv grass-6.2.1-1suse10.2.i586.rpm
> error: Failed dependencies:
> unixODBC is needed by grass-6.2.1-1suse10.2.i586
> fftw3 is needed by grass-6.2.1-1suse10.2.i586
> libfftw3.so.3 is needed by grass-6.2.1-1suse10.2.i586
> libmysqlclient.so.15 is needed by grass-6.2.1-1suse10.2.i586
> libmysqlclient.so.15(libmysqlclient_15) is needed by
> grass-6.2.1-1suse10.2.i586 libodbc.so.1 is needed by
These files need to be installes using your suse-installer called yast.
After that, you need to do:
This should work then.
Best
Stephan
Stephan Holl , http://intevation.de/~stephan
Tel: +49 (0)541-33 50 8 32 | Intevation GmbH | AG Osnabrück - HR B 18998
Geschäftsführer: Frank Koormann, Bernhard Reiter, Dr. Jan-Oliver Wagner
Send instant messages to your online friends http://uk.messenger.yahoo.com
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20070516/f53f9107/attachment.html
