[GRASS-user] which version of GRASS should I choose to install
in a Suse 10.2 i386 version ?
Otto Dassau
otto.dassau at gmx.de
Mon May 14 06:49:46 EDT 2007
On Mon, 14 May 2007 18:07:52 +0800 (CST)
Raymond Fu <raymond_fu at yahoo.com> wrote:
> hi Markus,Stephan,
> Thanks, it can proceed installation of first few files as stated in readme
file. However when grass-6.2.1-1suse10.2.i586.rpm is installed, it returns
below error? How can I proceed the installation? Do I need to install
certain extra file first?
> linux-s3qw:~/Desktop/GRASS# rpm -Uhv grass-6.2.1-1suse10.2.i586.rpm
> error: Failed dependencies:
> unixODBC is needed by grass-6.2.1-1suse10.2.i586
> fftw3 is needed by grass-6.2.1-1suse10.2.i586
> libfftw3.so.3 is needed by grass-6.2.1-1suse10.2.i586
> libmysqlclient.so.15 is needed by grass-6.2.1-1suse10.2.i586
> libmysqlclient.so.15(libmysqlclient_15) is needed by
> libodbc.so.1 is needed by grass-6.2.1-1suse10.2.i586
all depending packages are provided with your installation CD or DVD, or you can
download the packages from Opensuse:
http://download.opensuse.org/distribution/10.2/repo/oss/suse/i586/
in your case you probably need the packages:
- unixODBC-2.2.12-13.i586.rpm
- fftw3-3.1.2-19.i586.rpm
- mysql-client-5.0.26-12.i586.rpm
as Stephan said, the easiest way is to open YAST and search for the depending
packages.
regards,
Otto
> Thanks,
> Raymond
> Stephan Holl <stephan.holl at intevation.de> wrote: Hello Raymond,
> Raymond Fu , [20070511-17:28:04]:
> > Thanks. However when I run the installation, it returns errors as
> > belows. How can I proceed the installation? Did I miss certain
> > settings?
> > OSS at linux-s3qw:~/Desktop/Work/OpenSource/GRASS/SuseV10.2> rpm -Uhv
> > geos-2.2.3-1suse10.2.i586.rpm error: can't create transaction lock
> > on /var/lib/rpm/__db.000
> You need to be root to install RPM-packages. This should cure the above
> behaviour.
> Best
> Stephan
