[GRASS-user] which version of GRASS should I choose to install in a Suse 10.2 i386 version ?
Raymond Fu raymond_fu at yahoo.com
Mon May 28 06:57:26 EDT 2007
Dear Otto,
I try to follow the procedure in http://en.opensuse.org/Add_Package_Repositories_to_YaST to add a package repository.  I try to input server name: www.nature-consult.de, Directory on server:/software/suse/10.2/, as mentioned.
But it returned unable to create  installation source.
What parameter should I input?
Currently, I only miss the installation file, libmysqlclient.so.15.
What should I do?
Thanks a lot.
Raymond
Otto Dassau <otto.dassau at gmx.de> wrote: Hi Raymond,
you should find the procedure to add a package repository for Suse 10.2 here:
regards,
 Otto
On Wed, 16 May 2007 18:32:37 +0800 (CST)
Raymond Fu  wrote:
> thanks.  I can download all of the dependent file except libmysqlclient.so.15.
 I am using YAST to download (software-> add-on product).  But it need me to
tell the server.   How should I input?  or am I doing in the right way?
> Thank a lot.
> Raymond
> Stephan Holl  wrote: Hello Raymond,
> Raymond Fu , [20070514 - 18:07:52]
> > hi Markus,Stephan,
> > Thanks, it can proceed installation of first few files as stated in
> > readme file.  However when  grass-6.2.1-1suse10.2.i586.rpm is
> > installed, it returns below error?   How can I proceed the
> > installation?   Do I need to install certain extra file first?
> > linux-s3qw:~/Desktop/GRASS# rpm -Uhv grass-6.2.1-1suse10.2.i586.rpm
> > error: Failed dependencies:
> >         unixODBC is needed by grass-6.2.1-1suse10.2.i586
> >         fftw3 is needed by grass-6.2.1-1suse10.2.i586
> >         libfftw3.so.3 is needed by grass-6.2.1-1suse10.2.i586
> >         libmysqlclient.so.15 is needed by grass-6.2.1-1suse10.2.i586
> >         libmysqlclient.so.15(libmysqlclient_15) is needed by
> > grass-6.2.1-1suse10.2.i586 libodbc.so.1 is needed by
> These files need to be installes using your suse-installer called yast.
> After that, you need to do:
> This should work then.
> Best
>  Stephan
 Send instant messages to your online friends http://uk.messenger.yahoo.com
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20070528/65e006bc/attachment.html
