[GRASS-user] GRASS, qGIS and Mac OS X Problem
David Greenberg
david.greenberg3 at gmail.com
Mon May 14 21:29:00 EDT 2007
GRASS seems to be running OK, as does qGIS on OS X 10.4.9. I can
successfully launch qGIS from the GRASS terminal window. However,
when I try to import an OGR/PostGIS vector layer, I get an error
message that says:
ERROR 1: dlopen(/Applications/qgis-0.8.0/qgis.app/Contents/MacOS/lib/
gdalplugins/ogr_GRASS.so, 1): Library not loaded:
@executable_path/lib/libgdal.1.dylib
Referenced from: /Applications/qgis-0.8.0/qgis.app/Contents/MacOS/lib/
Reason: image not found
Any ideas? Thanks.
David
