[GRASS-user] No access to most of my point vectors
Agustin Diez Castillo
Agustin.Diez at uv.es
Fri May 18 12:18:36 EDT 2007
Michael,
Yes I did
v.build map=ACas260207b at adiez2 option=build
and not results, well yes those:
coor files of vector 'ACas260207b at adiez2' is larger than it should be
(15145471 bytes excess).
On May 18, 2007, at 6:15 PM, Michael Barton wrote:
> Agustin,
> Silly question perhaps, but have you run v.build?
> Michael
> On 5/18/07 8:47 AM, "Agustin Diez Castillo" <Agustin.Diez at uv.es>
> wrote:
>> I've lost access to most of my vector files in a mapset (adiez2 is
>> the mapset where I'm working even if it shows up like @ at the
>> GUI) Is there anyway to recover then other than reimporting the dbf.
>> When I try to deploy
>> d.vect map=ACas260207b at adiez2 color=0:0:0 lcolor=0:0:0
>> fcolor=170:170:170 display=shape type=point icon=basic/circle
>> size=5 layer=1 lsize=8 xref=left yref=center llayer=1
>> Size of 'coor' file differs from value saved in topo file.
>> Please rebuild topology for vector 'ACas260207b at adiez2'
>> Cannot open topo file for vector map <ACas260207_PS_EP at adiez2>
>> When I try
>> v.build map=ACas260207b at adiez2 option=build --overwrite
>> be (15145471 bytes excess).
>> Building topology ...
>> Registering lines:
>> But the dbf is there
>> ^C_^G^Z<E5>^@^@^@!
>> ^C5^A^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@str_1^@^@^@^@^@^@C^@^@^@
>> ^@*^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@int_1^@^@^@^@^@^@N^@^@^@^@^K^@^@^@^@
>> ^@^@^@^@^@^@int_2^@^@^@^@^@^@N^@^@^@^@^K^@^@^@^@^@^@^@^@^@^@^@^@^@^@^
>> @dbl_1^@^@^@^@^@^@N^@^@^@^@^T^F^@^@^@^@^@^@^@^@^@^@^@^@^@^@str_2^@^@^
>> @^@^@^@C^@^@^@^@^G^@^@^@^@^@
>> ^@^@^@^@^@^@^@^@^@^@str_3^@^@^@^@^@^@C^@^@^@^@^K^@^@^@^@^@^@^@^@^@^@^
>> @^@^@^@^@str_4^@^@^@^@^@^@C^@^@^@^@^V^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@st
>> r_5^@^@^@^@^@^@C^@^@^@^@^V^@
>> ^@^@^@^@^@^@^@^@^@^@^@^@^@^@int_3^@^@^@^@^@^@N^@^@^@^@^K^@^@^@^@^@^@^
>> @^@^@^@^@^@^@^@^@int_4^@^@^@^@^@^@N^@^@^@^@^K^@^@^@^@^@^@^@^@^@^@^@^@
>> ^@^@^@int_5^@^@^@^@^@^@N^@^@
>> ^@^@^K^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@int_6^@^@^@^@^@^@N^@^@^@^@^K^@^@^
>> @^@^@^@^@^@^@^@^@^@^@^@^@int_7^@^@^@^@^@^@N^@^@^@^@^K^@^@^@^@^@^@^@^@
>> ^@^@^@^@^@^@^@str_6^@^@^@^@
>> ^@^@C^@^@^@^@^C^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@int_8^@^@^@^@^@^@N^@^@^@
>> ^@^K^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@int_9^@^@^@^@^@^@N^@^@^@^@^K^@^@^@^
>> 0^@^@^@^@^@N^@^@^@^@^K^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@int_11^@^@^@^@^@N
>> ^@^@^@^@^K^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@int_12^@^@^@^@^@N^@^@^@^@^K^@
>> int_13^@^@^@^@^@N^@^@^@^@^K^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@int_14^@^@^@
>> ^@^@N^@^@^@^@^K^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@int_15^@^@^@^@^@N^@^@^@^
>> ^@^@^@str_7^@^@^@^@^@^@C^@^@^@^@^E^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@int_1
>> 6^@^@^@^@^@N^@^@^@^@^K^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^M Encantada
>> 730324 4300460 298.000000AC-enc Alc/Com
>> Lorxa ***********
>> 1 1 0*********** ****
>> *************** 999999 TOSSAL DE LA ROCA (VALL
>> D'ALCAL<C3><8B> 735500 42
>> 97100********************C70 Alc/Com ALCALA
>> VALL D'ALCAL<C3><8B>
>> **** 10070 COVA DE L'ALIGA (VALL
>> D'ALCAL<C3><8B> 740000 4298900******
>> **************C69 Marina AltaALCALA VALL
>> D'ALCAL<C3><8B>
>> 10069 PENYA DEL COMPTADOR (ALCOI 720900
>> 4282500********************C68
>> Alc/Com Serpis ALCOI
>> *************************************** 10068 COVA DE
>> PISCINA (BOCAIRENT 708000
>> 4294100********************C67 V. Albaida Albaida
>> BOCAIRENT
>> **************** 10067 ABRIC DEL BARRANC DE LES CALDERES
>> (PLANES 732900 4296700********************C66 Alc/
>> Com Almudaina Planes
>> 10066 ABRIC DE LA FALGUERA (ALCOI 720700
>> 4282900********************C65 Alc/Com Polop
>> ALCOI **********
>> ******************* 10065 COVA DEL GARR
>> OFER (ONTINYENT 708000
>> 4296900********************C64 V. Albaida Albaida
>> ONTINYENT *********************************
>> ******************* 10064 COVA DE LA GERRA (BOCAIRENT
>> 708500 4295400********************C63 V. Albaida
>> Albaida BOCAIRENT
>> ******************* 10063 COVETA EMPARET<C3><8B>
>> (BOCAIRENT 709400
>> 4293200********************C62 V. Albaida
>> Albaida BOCAIRENT
>> **** 10062 COVA DE LA SARSA
>> (BOCAIRENT 709900 4293400************
>> __________________________________________________________
>> Dr. Agustín Diez Castillo
>> Departament de Prehistòria i Arqueologia
>> Fundació General Universitat de València Phone: +34 963 98
>> 38 93
>> Avda. Blasco Ibañez, 28 Fax: +34 963 98 38 87
>> València 46010
>> http://www.uv.es/sidgeipa
>> Member of the European Network of Excellence EPOCH
>> http://www.epoch.eu/
> Michael Barton, Professor of Anthropology
> School of Human Evolution & Social Change
> Center for Social Dynamics & Complexity
> Arizona State University
> phone: 480-965-6213
> fax: 480-965-7671
> www: http://www.public.asu.edu/~cmbarton
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20070518/b6b2e399/attachment.html
