[GRASS-user] No access to most of my point vectors
Maciej Sieczka tutey at o2.pl
Fri May 18 14:22:10 EDT 2007
Agustin Diez Castillo wrote:
> Michael,
> Yes I did
> v.build map=ACas260207b at adiez2 option=build
> and not results, well yes those:
> coor files of vector 'ACas260207b at adiez2' is larger than it should be
> (15145471 bytes excess).
This problem can be solved if you just open the vector in v.digit and
quit. That will fix the vector.
Maciek
