[GRASS-user] grass 6.2 crashes when creating location
Travis Kirstine traviskirstine at gmail.com
Thu May 24 15:33:13 EDT 2007
I just installed grass 6.2 using the max rpms:
yum -y localinstall gdal-1.3.2-max.1.fc6.i386.rpm
gdal-devel-1.3.2-max.1.fc6.i386.rpm
gdal-grass-1.3.2-1.fdr.fc6.i386.rpm geos-2.2.3-1.fc6.i386.rpm
geos-devel-2.2.3-1.fc6.i386.rpm geos-doc-2.2.3-1.fc6.i386.rpm
grass-6.2.1-1.fdr.fc6.i386.rpm jasper-1.701.0.uuid-1.i386.rpm
jasper-devel-1.701.0.uuid-1.i386.rpm
Grass starts fine but crashes when creating a location based on
Projection Values.  Also, the EPSG codes are not available to create a
location base on EPSG codes.
I did have some issues installing the geos rpm (geos not signed error)
but I just edited the yum.config file: gpgcheck=0
Do in need the proj rpm from the min rpms  as well
Any Ideas?
Travis K.
Toronto, Canada
"She knows there's no success like failure
And that failure's no success at all."
-Bob Dylan-
