[GRASS-user] grass 6.2 crashes when creating location
Maris Nartiss maris.gis at gmail.com
Fri May 25 02:56:32 EDT 2007
It's fixed in CVS for 6.3. No ideas if it's backported to 6.2 (IIRC no).
Workaround - download Spearfish dataset, open it, close it and then try again.
Maris.
2007/5/24, Travis Kirstine <traviskirstine at gmail.com>:
> I just installed grass 6.2 using the max rpms:
> yum -y localinstall gdal-1.3.2-max.1.fc6.i386.rpm
> gdal-devel-1.3.2-max.1.fc6.i386.rpm
> gdal-grass-1.3.2-1.fdr.fc6.i386.rpm geos-2.2.3-1.fc6.i386.rpm
> geos-devel-2.2.3-1.fc6.i386.rpm geos-doc-2.2.3-1.fc6.i386.rpm
> grass-6.2.1-1.fdr.fc6.i386.rpm jasper-1.701.0.uuid-1.i386.rpm
> jasper-devel-1.701.0.uuid-1.i386.rpm
> Grass starts fine but crashes when creating a location based on
> Projection Values.  Also, the EPSG codes are not available to create a
> location base on EPSG codes.
> I did have some issues installing the geos rpm (geos not signed error)
> but I just edited the yum.config file: gpgcheck=0
> Do in need the proj rpm from the min rpms  as well
> Any Ideas?
> Travis K.
> Toronto, Canada
> "She knows there's no success like failure
> And that failure's no success at all."
> -Bob Dylan-
> grassuser mailing list
> grassuser at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grassuser
