[GRASS-user] grass 6.2 crashes when creating location
    Travis Kirstine
    traviskirstine at gmail.com
    Fri May 25 13:58:10 EDT 2007
Maris,
I gave your workaround a try but Grass crash right after I "Enter
Grass".  Is it possible to create a fresh install.  I attempted  yum
remove ....rpm but with no luck
On 25/05/07, Maris Nartiss <maris.gis at gmail.com> wrote:
> It's fixed in CVS for 6.3. No ideas if it's backported to 6.2 (IIRC no).
> Workaround - download Spearfish dataset, open it, close it and then try again.
> Maris.
> 2007/5/24, Travis Kirstine <traviskirstine at gmail.com>:
> > I just installed grass 6.2 using the max rpms:
> > yum -y localinstall gdal-1.3.2-max.1.fc6.i386.rpm
> > gdal-devel-1.3.2-max.1.fc6.i386.rpm
> > gdal-grass-1.3.2-1.fdr.fc6.i386.rpm geos-2.2.3-1.fc6.i386.rpm
> > geos-devel-2.2.3-1.fc6.i386.rpm geos-doc-2.2.3-1.fc6.i386.rpm
> > grass-6.2.1-1.fdr.fc6.i386.rpm jasper-1.701.0.uuid-1.i386.rpm
> > jasper-devel-1.701.0.uuid-1.i386.rpm
> > Grass starts fine but crashes when creating a location based on
> > Projection Values.  Also, the EPSG codes are not available to create a
> > location base on EPSG codes.
> > I did have some issues installing the geos rpm (geos not signed error)
> > but I just edited the yum.config file: gpgcheck=0
> > Do in need the proj rpm from the min rpms  as well
> > Any Ideas?
> > Travis K.
> > Toronto, Canada
> > "She knows there's no success like failure
> > And that failure's no success at all."
> > -Bob Dylan-
> > grassuser mailing list
> > grassuser at grass.itc.it
> > http://grass.itc.it/mailman/listinfo/grassuser
Travis K.
Toronto, Canada
-Bob Dylan-
