[GRASS-user] Fwd: Not able to retain vector points
Carlos "Guâno" Grohmann
carlos.grohmann at gmail.com
Fri May 25 14:13:44 EDT 2007
Forwarding a msg sent to me instead of the list by
Agustin Diez Castillo <Agustin.Diez at uv.es>
where there is >200 points I see nothing. I've tried v.build and
v.digit with no success. In the dbf there are the point I either
v.in.db or v.in.ascii
coor files of vector 'ACas20070519 at adiez2' is larger than it should be
(14 bytes excess).
Building topology ...
Registering lines:
0 primitives registered
Building areas:
0 areas built
0 isles built
Attaching islands:
Attaching centroids: Topology was built.
Number of nodes : 0
Number of primitives: 0
Number of points : 0
Number of lines : 0
Number of boundaries: 0
Number of centroids : 0
Number of areas : 0
Number of isles : 0
Registering lines:
Building areas:
0 areas built
0 isles built
Attaching islands:
Number of nodes : 0
Number of lines : 0
Number of areas : 0
Number of isles : 0
Carlos Henrique Grohmann - Guano
Visiting Researcher at Kingston University London - UK
Geologist M.Sc - Doctorate Student at IGc-USP - Brazil
Linux User #89721 - carlos dot grohmann at gmail dot com
_________________
"Good morning, doctors. I have taken the liberty of removing Windows
95 from my hard drive."
--The winning entry in a "What were HAL's first words" contest judged
by 2001: A SPACE ODYSSEY creator Arthur C. Clarke
