[GRASS-user] TIN algorithm
Hamish
hamish_nospam at yahoo.com
Sun May 27 08:22:08 EDT 2007
Carlos wrote:
> I was just reading an interesting paper about the DEST algorithm to
> poduce TINS, and I was wondering how are TIN-related stuff in GRASS? I
> never needed, but.. it is possible? to generate a real TIN?
TINs are just xyz points joined together, e.g. with v.delaunay.
http://www.ian-ko.com/resources/triangulated_irregular_network.htm
I had thought there was a script on the wiki add-ons page, but I don't
see it there now. (to do v.delaunay + v.distance to apply elevation
value to triangle centroid?) Maybe google could find it.
r.refine, again from Laura Toma's group:
http://www.bowdoin.edu/~ltoma/research.html
TINs + GDAL:
http://lists.maptools.org/pipermail/gdal-dev/2007-January/011633.html
also, in the GRASS 6 vector lib there is lib/vector/Vlib/tin.c. I don't
really know what it does, but d.what.vect calls it.
Hamish
