[GRASS-user] v.in.ascii don't work
Massimiliano Cannata massimiliano.cannata at supsi.ch
Tue May 29 06:26:47 EDT 2007
Hello,
try
g.gisenv set="DEBUG=5"
 to set the max debugging level.
or take a look at
http://grass.gdf-hannover.de/wiki/GRASS_Debugging
for further info on debugging.
regards,
Maxi
Poizot Emmanuel wrote:
> gary a écrit :
>> When I had a similar problem, I ended up using csv file from a
>> spreadsheet as the input file.
>> Otto Dassau wrote:
>>> Hi,
>>> for me (GRASS 6.3cvs) the import of your test data works, the syntax is
>>> correct. Maybe you need to check your test.txt for <space> values in
>>> your
>>> columns etc?
>>> regards,
>>>  Otto
>>> On Tue, 29 May 2007 09:31:38 +0200
>>> Poizot Emmanuel <poizot at cnam.fr> wrote:
>>>> Hi all,
>>>> I'm unable to input  text file in GRASS using v.in.ascii.
>>>> I'm (trying) working on GRASS 6.2.1 under Ubuntu Fiesty
>>>> I have a text file (test.txt) which containing:
>>>> 1|3.5|43.6|2.3
>>>> 2|3.55|43.605|1.2
>>>> 3|3.51|43.621|-2.3
>>>> 4|3.485|43.704|56.1
>>>> 5|3.498|43.5|7.1058
>>>> I would like to import it in a new layer with the following command:
>>>> cat test.txt | v.in.ascii  out=test columns='nul int, x double, y
>>>> double, val double' fs="|" x=2 y=3 z=0
>>>> and the outputs of that command is:
>>>> Maximum input row length: 20
>>>> Maximum number of columns: 4
>>>> Minimum number of columns: 4
>>>> column: 1  type: integer
>>>> column: 2  type: double
>>>> column: 3  type: double
>>>> column: 4  type: double
>>>> Building topology ...
>>>> 0 primitives registered     0 areas built     0 isles built
>>>> Attaching islands:
>>>> Attaching centroids: Topology was built.
>>>> Number of nodes     :   0
>>>> Number of primitives:   0
>>>> Number of points    :   0
>>>> Number of lines     :   0
>>>> Number of boundaries:   0
>>>> Number of centroids :   0
>>>> Number of areas     :   0
>>>> Number of isles     :   0
>>>> So no points are imported in the layer.
>>>> I turn around that problem wich normally should work, as what I
>>>> raed everywhere, but not for me !!
>>>> Regards
>>>> E. POIZOT
>> grassuser mailing list
>> grassuser at grass.itc.it
>> http://grass.itc.it/mailman/listinfo/grassuser
> Hi,
> I check for spaces on columns, misllaneous character, etc. The text
> file is clean.
> I also check the bounadries of my region settings and it's ok, the
> points are inside it.
> I just produced a CSV file from a spreadsheet, and still not work.
> How to know what happend durin v.in.ascii execution (debug or a log
> file) ?
> Regards
> EP
Type: text/x-vcard
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20070529/7d3d1cf4/massimiliano.cannata.vcf
